I’m a still learning woodworker-I am making a desk out of cherry. I had some problems with tearout while using my router and am looking for advice on how to make sure the stain matches up nicely over the repaired spot. I used cherry wood filler (Famowood).
DKemmer,
You've probably created quite a headache for yourself. The wood filler will, in all probability, accept stain very differently than the surrounding wood. That kind of "repair" is something that takes a lot of experience with hand applied stain and dye to match. There is no telling how the real cherry and the "cherry filler" will differ in their receptivity until you try to stain or finish it. It might be a help to apply the filler to a scrap of the cherry used for the piece, sanded and prepared exactly as the final piece, then try your stain/dye/finish on that.
Rich
Thanks! I'll just have to file this under "learning the hard way"!
take some sawdust from your cherry wood pack it in your tear out or dent or what ever and then add a couple drops of model airplane glue. If you build it up a little you can sand it down for a perfect match. I got this info from my mentor, hope it works. I would try on a scrap piece first.
I haven't heard of this before! I hope it works. Thank you very much!
