Was wondering if anyone could recommend a decent wood filler that wont shrink.
Heres what happened, I started making the card table by Steve Latta in recent FWW, am gluing up the poplar bricklaid core. Have the third layer on and began routing it flush to the second layer, thought I was being careful, not too much overhang to trim, etc. Well , I guess I caught the grain where I should have been climb cutting and didnt notice it till it was too late, ( ok guys , I know this never happens to anyone else) and a large sliver flew off, perhaps 116d x14w x 1.5 inch long. I cant find it or I’d just try to glue it back in. Im guessing that wood filler is my next best fix, my concern with that though is that if the wood filler shrinks undeer the veneer might it create a bubble? or am I just thinking this too far.?
Whaddya think? Eric
Hi,
if i understand you correctly, the repair will be hidden under a layer of veneer. if so, then the look of the patch is unimportant. In the shop i work in, for this kind of repair we routinely use auto body filler (such as Bondo). It doesn't shrink, sands and shapes very well and is pretty cheap as well. i would test this with some scrap before commiting to doing this on good wood, but I think this will work for you.
-phil
Eric, Try DURHANS ROCK HARD PUTTY Most big box and hardware stores stock it
Just mix with a small amount of water and apply with a spatula to dry 'proud' of the surface then sand away excess an hour later.
If you have to fill a DEEP hole, it's best to do it in two layers.
The stuff is a powder and lasts almost forever on the shelf and after a few hours becomes ROCK HARD. You can drill holes in it/stain it/ paint it/mold it/ carve it and it drys to a pale cream color.
Guaranteed not to rubble up, doubble up, shrink, stink, or boil over
(I made that last one up)Steinmetz
Thanks for the reply guys,
as soon as I dig out from ma natures latest and greatest , Ill check out those products. The auto body filler I had heard of using but it did not occur to me, Durhans Putty,I did not know about.
Eric
LMAO,
Reminded me of an old chief, back in my Navy days. he use to say
"Guaranteed not rust, bust, bend or buckle, and fit for a fine example of a North American Blue Jacket"
Thanks for the reminder.
BTW, Durham is the way to go.
Dave
One of my stock phrases, is an old tailors adage "Guaranteed not to rip, ravel, or run at the seam"
Whatever.
Jim
Have you tried the two part Minwax filler? You can find it at any box store. It works alot like bondo. That has been my favorite for painted surfaces. I've never noticed any shrinking on anything I've filled. I worked at a "high quality" (read expensive) fence company when I was right out of high school. We used to use the Minwax filler by the case full for all our decorative pieces. (If people only knew how much filler was in those posts that cost them thousands of dollars!)
Eric, it's usually not the filler that shrinks, but the wood. There are many good fillers out there, Famowood is one of my favorites. You may be able to patch the problem with wood, which would be my first choice. Cut out a bit more and glue in a patch.
Thanx to all for their responses. Actually hammer, thats pretty much what happened. While I was waiting for the storm to finish, so Icould dig out and get to the store. I decided to clean up a bit more in the shop. Actually did find the chip, Most of it still fit from whence it came. so I glued it up , the little bit that was left (maybe an eraser size?), filled nicely (durhams) and sanded out well. Again thanx to everyone.
Eric
I'm going to agree with what others have said, if you're going to have it hidden by veneer, it doesn't matter what it looks like so long as it's stable. I've used both bondo and standard putty and both have worked just fine. You're really just looking for a surface to adhere the veneer to anyhow so it's six of one, half a dozen... you know...
