Hello all I am going to make a dough bowl an would like to know what woods are safe to use? The bowl that I have been ask to make will be 3x9x30 if I con’t find a carving block that big can I glue up some boards? If so what would be a safe strong glue to use? I will be using Kerf’s lemon luster and Kerf’s wood cream to finish the bowl
Maple is frequently used for bowls like that.
Several turners in our club avoid using nut woods (pecan, walnut, hickory, butternut, etc.) because of possible end-user allergy problems, you might want to consider that when you plan.
Thank you for binging that to my attention
jim
would,
Most dough trays in this area (Virginia's Shenandoah Valley) are poplar (tulip poplar, liriodendron tulipfera) , as it was available in large chunks (the trees are large and relatively fast growing) and soft enough to carve easily, stable enough to dry without severe checking.
ok Ray thank you
jim
Along the southern coastal plain the wood of choice is tupelo gum. Tupelo trees grow in water and have a large butt swell like baldcypress. This butt section is commonly used for dough boards. It's white, fairly soft and dries without checking. I have one which has been in the family for nearly 150 years.
thanks for your help
Jim
Tulip poplar was used in most of Appalachia.
thank you
Jim
