Hi all, over from Breaktime. I am trying to find a recipe for treating wood handles on my shovels, rakes, pitchforks, etc. I live outside Denver and the weather is is real burden on wood handles. Tools are in for the winter but spend the summer outside. I don’t mind puting the work into sanding and sealing. I just need a good recipe for handles that is not greasy or slick. Thanks, Tim
My tool handles get a 50/50 mix of BLO and mineral spirits, passed down from my Grandfather to Dad to Me. Seem to work fine.
Bruce S.
Thanks, that looks good! I'll do upp a few sticks tonight.
Raw linseed oil has been the traditional treatment for tool handles. It is claimed that handles treated that way do not cause blisters and they are not slippery to sweaty hands. However, linseed oil, whether raw or "boiled", will not provide any protective coating. Water and watervapor goes right through linseed oil.
Most tool handles seem to have a thin lacquer finish on them. I guess that you could lightly sand them and then apply a couple of coats of a poly varnish. However, varnishes tend to be slippery particularly if your hands sweat.
No matter what you put on the handles, if they are left outdoors exposed to the elements and UV from sunlight, the finish will not last.
;o) Ah, Howard, that's NO problem in Denver. There is NO water vapor!!!Gretchen
Your correct! Only water here is from my irrigation sys.
Guess I must be skiing on frozen martinis.
Seriously, I guess I would probably just go with raw linseed oil. On further thought, I'm not sure that any finish is necessary.Howie.........
Sand the handles. Wet sand the handles.
Slather on a coat of boiled linseed oil, wipe off the excess. Repeat every day for a week.
Slather on another coat of blo, wipe of the excess. Repeat every week for a month.
Slather on another coat of blo, wipe of the excess. Repeat every month for a year.
Slather on another coat of blo, wipe of the excess. Repeat once a year.
That's how I did our paddles. We can spend all day, day after day, working those paddles and never a blister. One day we went with a friend who had a varnished handle on his paddle. OUCH, he was a hurting puppy.
Relative humidity? = water vapor.Gretchen
EdHarrow has a good recipe. However, dry air & sunlight are harder on handles than the conditions his oars see. Recoating annually is a good idea for garden tool handles. Daily cleaning off dirt & storing them in a sheltered place will preserve them better than any coating. Perhaps you need a tool cart?
Cadiddlehopper
LOL, perhaps I should add the universal disclaimer, YMMV. ;-)
Will my feelings be hurt when I learn the meaning of YMMV?Cadid
Oh I don't think so. "Your Mileage May Vary." ;-)
