I started my Cheval Mirror project thinking my wood had dried to about 10 on the moister meter. After cutting out most of the pieces I discovered that the wood was reading 12 to 14 on the meter. The pieces are one & 1/2 inches thick and consist of two pieces glued together as suggested yesterday. Are these pieces going to hold true or am I wasting my time and wood? I also have to turn two post from the same wood. Maybe I should just go buy some dried wood? Appreciate any help. Thanks, Agriffee
I don't know for sure what the answer to the first part of your question is, but as far as buying "dried wood" I've learned the hard way that kiln dried wood from the lumber store is not necessarily stable. I'm not talking about a big box store either, but a local lumber store.
How wide are your 1.5" thick pieces??
The narrowest piece (frame) is one & 1/2 inches wide. I may have misinformed, the frame pieces are one & 1/4 inches thick. Other parts are wider, 4 inches and the post will be turned to one & 3/4 inches. You're right I bought some cherry wood that tested 12 on moister meter. Thanks very much I think I'll chance it. You must get up very early since you sent that message so early.
As for the turned pieces, the turning & sanding process is going to heat up the material and potentially bring the MC down quite a bit. At least that's been my experience.
woodnut@anatechsys.com
Thanks, appriciate your help. I think I'II chance it.
Actually turning is best done with green wood....
