I would like to know at what thickness of wood marquetry does wood movement become a problem. I am planning a dining table with various woods(zebrano, wenge etc) glued to a substrate. I am cutting my own veneer and am thinking of working in the 1/8 to 1/4 inch range for thickness glued to 3/4″ stable substrate.
Thanks so much in advance
Joe
Here's a great resource in general for wood shrinkage and expansion:
http://www.woodbin.com/calcs/shrinkulator.htm
You didn't mention what your maximum width and lengths might be.
What is the substrate? Generally, 1/8" is as thick as you should use.
Be sure to plan to do something on the other side of the substrate or you will get warping.
Dimensional changes in wood is a factor in all thicknesses!
Here's a link to "Just Woodworking"'s on-line page about wood movement. There's a link at the top of the page that allows you to download a wood movement calculator to your PC.
I do table tops and dressers in 1/8" x 8/4 x 4' hardwood strips over 1/4" ply. You need a good glue. I use epoxy. And a good sealer. I use epoxy.
A bit of hard varnish works well over epoxy.
I am sure other people work differently.
Hi,
The reason I want to go thicker than veneer and use 1/8 to 1/4 is that I want it to last and ware for some time. Do you also finish the otherside of the plywood with wood to stabilize it?
Joe
Always
