I am building a table out of solid 3/4 cherry and 72″ (36″ per side split in the center for a leaf.) in length. I am interested to know how much movement to allow for the top. The tap will sit on a a frame of laminated cherry. The top split in half for a table leaf of 22″ to be added.
It is fashioned after a Thos Moser Four Leg Oval Ring Extension Table
Any help appriciated.
Jim
Go to: http://www.woodbin.com and click on the "Shrinkulator". Plug in the species, width and relative humidity range and it will calculate the expansion/contraction.
Which way will the grain run? If you are going to have a leave in the center, it is normal to run the grain across the shorter dimension of the table. If this is the case, figure 36" as the width.
Also, you need to figure where to hold the tabletop fixed. Normally, the tabletop is fixed at the center and the ends allowed to move.
Figure on about 0.1" for each 1% change in moisture content for 36" wide Black Cherry. So with the MC changing from 8% to 11%, and with a 36" glue-up, you could expect an expansion of 0.3". Or, a 0.3" contraction if going from 11% to 8%.
To be on the safe side, use +/- 1/2". Here in Houston I assume that MC will decrease when moving a piece from my shop into the house (no way in HE-- it could increase).
Tangential Coefficient for Black Cherry is 0.00248. Radial is 0.00126.
Delta = Width(Ct(11-8)) = 36(0.00248(3)) = 0.27"
A common way I use to float a table top is with slots in the inside of the side skirts with a metal clip secured to the top that will move back and forth in the slot. Wax the slot so the clip will be able to move. Lightly snug it down. Remember that the radial contraction will be about one half that of the tangential.
Also, considering all the common American hardwoods, the highest Ct is about 0.0043 (Beech) and the lowest is about 0.0022 (Butternut). Cr is always about half of Ct.
For softwoods, Western Larch has the highest Ct, being 0.00323, and Cedar the lowest coming in at about 0.0017.
Hope that helps!
PlaneWood by Mike_in_Katy
PlaneWood
Edited 1/9/2003 12:53:19 PM ET by PlaneWood
Edited 1/9/2003 1:02:06 PM ET by PlaneWood
Expansion table for hardwoods
Thank you very much for your help.
Jim fassino
Your very welcome.
If you use quarter sawn lumber, then use the 'radial' figure instead of 'tangential'. Half as much expansion/contraction. When doing the glue up, alternate the growth rings. i.e. don't have the direction towards where the bark of the tree was the same for any two adjacent boards.
