What can I use to seal the edges of plywood that will be exposed, to lessen moisture from wicking into the wood? I have heard of “clear penetrating epoxy sealer” but know nothing about it. Thanks.
interior? exterior? wet or dry location?
Location is inside screened in pool area in a house located on water. Will be a table top . Thnx.
Search Smith & Co , restoration products, Richmond, Ca. They make the epoxy sealer that you are looking for. I believe that you can buy direct. Sorry I didn't post the direct link.John
