Hello- this is my first post here on Knots, and if i bore you with my seemingly stupid question…sorry.
I have outswinging casement windows at home, and I want to build interior screens that would swing in to allow to open the window.
I was planning on using 5/4″ poplar and staining to match the existing woodwork; also, I was going to use a hinge that had a pin for easy removal during winter months.
Any suggestions on wood species and/or joinery? I don’t have a drill press/ mortise bit….yet. Thanks!
I would use cedar or redwood if I understand what your trying to do.
Since they are interior, poplar is fine.
Since they are casement windows and likely to be small, and since they are only holding screens, there's practically no weight for them to support. Joints need not be extra strength. You could probably get by with screwed and glued butt joints for this job, since you'll be painting over everything. Just be sure to pre-drill holes, countersink for a plug, and Bob's your uncle. If that option is too ugly for you to consider, then try simple lap joints cut on your tablesaw.
Keep the posts coming, none are stupid or boring.
Bob's your uncle?Kenneth Duke Masters
The Bill of Rights
December 15 1791
NRA Endowment Member
LEAA Life Member
CRPA Member
Bob's your uncle?
Old saying meaning nothing more to say or do.Recommending the use of "Hide Signatures" option under "My Preferences" since 2005
with my seemingly stupid question...sorry..
Geeee... Only stupid question is when the 'little lady' asks ya somethin' and ya say 'what?'
I use poplar ALOT for many different things..
If painted?.. I'd just use good old pine! .... Cheaper around here...
Stain on poplar or pine is REALLY hard to do if you want to MATCH another wood finish... Your call..... But if sanded well, you can use a water based GEL stain... and get a pretty good finish and color match..
You got hardwood trim? If so use the same type of hardwood.. BUT harder to work with... You never stated what tools you DO have...
For a screen you do not need much strength at the joints so maybe just a mitered half lap?? Whatever... Joint/wood type could be a problem on the windows that 'see' the HOT sun during the day though.. But then again almost ANY wood would have that problem..
Just me!
Old or new windows? What Mfg.. If you know the brand they may have something that 'snaps' on made of aluminum OR FAUX wood... In color of your choice..
Edited 6/15/2005 11:26 am ET by Will George
thanks for the info.
original 1920's windows...i've been told poplar is difficult to stain. someone suggested using a pretreatment that cuts some of the wood's oils and allows it to accept the stain a little better.
i have no idea what the original hardwood trim is, but i started to strip some of the trim in an upstairs bedroom and believe it is pine...but that is painted. the woodwork on the casements and the jambs are stained.
thanks again.
i've been told poplar is difficult to stain.. I find ALL wood is but then again I hate doing it!
Poplar is difficult to stain. I'd recommend pine,fir,maple,cherry, anything else.
Standard hinges with removable pins work fine and don't require special tooling to install.
