Hi I routered a welcome sign using poplar wood. I used a 1.8″ endmill bit and cut to a depth of 1/8″. I want to make the cut black and stain the wood surface with an oak stain. Using a brush with black paint is slow and tedious and stills gets black on the surface. I tried using black spray paint, black stain with a sponge or rag. But I can’t sand the black completly off. It penetrates the wood to where I end up sanding the routered text off.
Is there a product I can use that won’t penetrate the wood so much?
Just a guess, but you might be better off finishing the board before cutting the letters. The black paint won't penetrate the surrounding wood if it's finished.
Rout your sign, stain the surface, seal the entire piece, then go back and paint in the letters.
What they said. Once your sign is sealed you can easily and quickly apply black paint where it is desired without to much care then simply wipe the excess off.
If the sign will be outside you can then apply an additional coat or two of exterior finish(make sure it's compatible) to the entire sign adding to the longevity and durability.
Or, you can rout it, paint the whole thing & put it through a planer to get rid of the over-spray.
Mikaol
Haaaaaa...it would work! Go with whatever's hardest.
