I’m trying to locate a 3/8″ wood threading bit.
I have only seen the wood taps and dies in sizes 1/2" and larger. I wanted to use a 1/4" on a past project.
The largest one I have seen is 1/2". Don't think they come any smaller.
Scott C. Frankland
Jim,
A threaded dowel any smaller than a 1/2 inch would have fragile threads, so that is the smallest size made to my knowledge. You can use a metal tap to thread wood in smaller sizes but you won't be able to create a threaded wood dowel to match that would be of any practical use.
Beall Tool Co. is the company best known for wood threading tools. You might contact them about getting something smaller than a 1/2 inch, which is the smallest size in their catalog.
The coarsest 3/8 inch diameter thread is 3/8-16 which is commonly available. With metal bolts a 3/8 thread in wood is quite strong. To create stronger threads in wood, you can use metal inserts or helicoils.
John W.
Thanks, I was looking for a particular size (3/8s 8TPI) to replace a missing knob on an old Stanley plane. I ended up dragging out my metal lathe and turning one.
