The truth is that woodworking clamps not exist without the existence of clamps in the first place because it is the clamp which holds the wood or the wooden parts together, without the clamps the wooden pieces would fall apart and it would be impossible to work with them. However some argue that there is always another solution for this and that is to glue the wooden pieces together in order to work with them.
While it is true that gluing the pieces together does the same job of holding the pieces or fastening them together with a clamp, but what happens after you are done working with the piece and you need to detach the pieces? It would not be pleasant or easy to remove the glue and even if you manage to remove them, they might leave behind some sticky and stubborn residue which mars the beauty of the wood. Hence woodworkers appreciate clamps a lot and they understand their importance.
A person once sold off all the articles of a workshop by advertising each article or tool separately. At the end of the first day, the person received a barrage of requests for the clamps. This goes to show how important the clamps are for woodworking and that these two go hand in hand and clamps are indispensable when it comes to woodworking. It is just that sometimes we fail to understand or realize the importance of these humble woodworking clamps
Clamps
Wasn't there an old TV show about a family named the Clamp-its? ;-)
Clamp
Yes and I think Jethro wrote the initial post above.
SA
Don't insult Jethro
SA
Nah, Jethro had a 6th grade ejumacation. That's a few grade levels above this poster. Bad part about it, there's been more
Another example
of why it is not a good idea to post comments on a blog while smoking crack...
Clamps
Huh? Am I missing something here or is it just my OFS taking control?
