Hello all, I’ve always liked working with wood, and I am now intending to get started with finer woodworking, building some furniture.
One challenge I have is that I have psoriasis including hand psoriasis. I have one rule about this though and that is, if it is in any way possible, the psoriasis does and should not influence what I do.
If I do work with my bare hands they further dry out, crack, bleed, itch, blister, scale, …. When I do manual work I therefore put cream on my hands, put on surgical gloves and then wear tougher gloves above this. This keeps it manageable.
Now I realise that for finer woodworking and working with rotating machines it’s probably not a good idea safety and tactile wise to wear heavy gloves… My intention is therefore when required safety wise to only wear the surgical gloves.
Any thoughts, advice on what I can do to make woodworking as a hobby possible for me? Anybody else has experience with woodworking with hand psoriasis or eczema and wants to share tips?
Thanks in advance.
Think 18th Century
Some extremely fine pieces furniture were made only with hand tools.
But there are power tools that I would feel comfortable using with " sport type"(golfing/batting) gloves on. Band saw, Power surfacing planer, drum sander. I would AVOID table saw, drill press, jointer.
I use surgical gloves in my photo darkroom, particularly when developing sheet film in trays (in total darkness, of course).
For shop work, heavier nitrile gloves stand up better. You might also look at gloves intended for automotive work.
I'm also a big believer in push sticks, blocks, and jigs. My hands never get close enough to a moving blade to be an issue.
