I’m building a Roubo- wondering why the endcaps seem to be always made from a single large (expensive) block of wood instead of laminating several smaller pieces.
Glue joints are stronger, lamination’s are stronger and more stable.
Any insights would be appreciated.
Thanks!
Endcaps?
Are you talking about the apron or end cap? Traditionally they were solid because either there weren't adhesives available or the adhesives were that strong. There's nothing stopping you from making yours by laminating multiple pieces. I would make mine from a single piece so I don't have to worry about glue creep or weird seasonal movement.
I am talking about the end cap that the tail vise uses to create force. It's attached to the rest of the bench w/ a tenon and often a dovetail.
I would think w/ modern adhesives it wouldn't be much of a risk, but the wood isn't that expensive, so why take that risk.
Thanks!
With modern adhesives if wouldn't be a risk at all. You could even skip the dovetails where the end cap and the front apron are joined. You'll still need to make sure you do the breadboard end (wide mortise and tenon) correctly no matter how you build the end cap.
