I’m considering the purchase of a traditional bench holdfast. I’m a little reluctant to drill a hole in my Ulmia workbench. Should I be concerned? Based on experience what are the best locations for the holes?
Mike -- I have the model Ulmia with round holes and just use them without the need to drill new ones. You can probably use the square ones the same way. There are two models of the cast iron holdfasts and I had to get the larger one in order for it to grip well in the Ulmia holes. However, because of the longer shaft, I had to saw off a few inches so it wouldn't run into the shelf below the top. As for position, I find using one of the existing Ulmia holes that is close to one of the bench's edges or vice to work just fine and haven't had to drill special ones, although I'm sure some work pieces might require it. If so, just do it and maybe take an asprin after -- yuk yuk. Jim
Agree with Jim. I am currently making a new work-bench an chose to use round holes instead of traditional square ones. I feel it gives me more options (like Veritas Wonder Dogs that can really reach out).
I have used the hold downs you refer to on past benches an they are good in most situations. If you have an extremely wide top, they might come up a little short. You could also add a row of round holes half-way between your existing ones. That way you enjoy both worlds.
If you do drill, make a template for the drill bit on the DP. After marking your spots an tapping the center with a punch, clamp the template over the taps. Start with a Forstner an if it won't go completely through, use a longer spade bit with a clamped on piece under-neath for backing to avoid tear-out on exit. This template will guide a hand-held drill perpendicular till you hit pay-dirt.
I know it's a beautiful Ulmia. But if it can't do what you require for your style, what's the point. Work-benches are made for work, let it do what it was created for. If it ain't scuffed, it's probably still on the show-room floor.
Then, there's always duct-tape. It will hold about anything you throw at it. he..he..
Good luck...
sarge..jt
