Hi, I have come into some 8/4 maple which I was planning to use for a workbench. The problem I am having is that boards are only 4′ long, but I would like my bench to be at least 6′ long. Would it be OK if I glued the boards together to get the length I would like and what would be the best approach to take to accomplish this task? Thanks
8/4 Workbench
Hi,
Congratulations on your acquisition, a workbench is a perfect use for it.
Assuming the boards are wide enough and flat sawn, you could cut them cut them into 2 in wide strips (or however thick you want the top) turn them 90 degrees and glue them up. Alternate the the side the 2 foot piece goes on, kinda like laying bricks, and presto, instant laminated, stable, quartersawn workbench top.
Biscuts or splines aren't a bad idea to help keep the boards from shifting, which the wide glue joints like to do. Avoid gluing up more than say 4 courses at once, too many things can go wrong. If you have a planer, make the laminated boards a little thick and run through the planer to finish (light cuts, quartered maple likes to chip). The planed laminated boards can be carefully glued together to make a wider top.
Workworkers Bench
Thanks I will be that a try.
