I am thinking about using a Douglas Fir Glulam beam as a workbench top. I can get a 3 1/8″ deep X 22″ wide X 8′ long from a local lumber yard. I plan to rip off the rounded edges, add a 5″ deep skirt all the way around, and flatten the top with a router. Adding two high-quality vises, boring bench dog holes, and mounting on a sturdy base, I think, will produce a fairly serviceable bench. I know that Doug Fir is not hard maple but it is a lot less expensive.
In your opinions is this a worthy endeavor? What pitfalls should I anticipate? Will Watco oil or equivalent seal the Doug Fir well enough that I don’t have pitch oozing on to the working surface? Will the Glulam’s moisture content pose a problem?
I am new to serious woodworking so any help would be most appreciated.
James
You could easily cover the top with maple or some other hardwood. How would the cost compare? A lot of glulams have a crown in them.
I made a workbench top out of old doug fir roof rafters and it has worked fine I think your gluelam should work well also, just check it for flatness. I saw a 24" wide Oliver Jointer on e-bay that would make quick work of flatting it;) or you could use a jointer plane.
happy holidays and all of that
troy
I just finished a 36" x 102" edge grain 8/4 Maple top for my new bench. It is BEAUTIFUL but I have $800.oo in the darn thing.
Edited 12/26/2006 6:52 pm ET by mbcabinetmaker
Firstly, let me thank you all for your replies.gb93433 - I am pretty sure that one can specify that the glulam not be crowned.Troy - The 24" Oliver Jointer would do the trick. Got an appointment with my banker tomorrow. mbcabinetmaker - Maple would be my choice but I need to do this on a tight budget.Keep the info coming.James
I used to work at a glu-lam manufacturer. Glu-lams can be specified without camber (crown) although depending on where you live, there will only be between 1/32" - 1/16" of camber in an 8' length. It won't affect the beam in terms of surface flatness since it will be lying on it's side. While I was there, I had a desk/hutch made out of glu-lams and it was very nice. I had it planed down to just over 2" thick and it served me well. I just had them apply some regular varnish and it made for a cool looking desk. The moisture content of glu-lams at time of manufacturer is typically around 12% and the only time you normally see a lot of checking is in the very dry climates such as Denver and Phoenix.
You can take your piece of glu-lam to a cabinetmaker's shop and run it through their drum sanderas I did- Quick, inexpensive and flat-
James,
Since maple is your choice, I will tell you how I made mine, and you can decide for yourself. I too was on a tight budget but desperately wanted a maple top.
I took 2 sheets of 3/4" plywood, ripped them to the bench width (24" in my case) and glued them together. I didn't want to put screws or nails in the top because of drilling for the dog holes later. Then I took a 8/4 hard maple board and ripped 3/8" strips from it. A 3/8" thick strip will take 1/2" width from the maple board because of the 1/8" kerf. You will net 2 strips per inch of board width. A 8" wide board will give you 16 strips. Plane these strips down to clean them up (with a planer), you probably can end up with 5/16" thick strips if you are careful. I glued these 1 at a time to the plywood with a special jig I made. Then I faced the entire bench with 3" wide X 2" thick solid maple so you couldn't see the plywood. The top came out very flat, and wears like a solid bench because of the thickness of the maple on the top of the plywood. All I had to do was some light sanding to flatten the top. The individual pieces pulled together very tightly - make sure you have no snipe on either side of the board you are using before you rip the strips, that will show up as a gap when you mate the strips together. Also, my boards were flatsawn which yielded mostly quartersawn strips for the top
Total cost was 2 sheets 3/4" plywood and 2 - 9" wide 8/4 maple boards 8 feet long. My bench is 30" wide (24" for the top and a 6" tool tray) by 7 feet long.
I am enclosing a pic so you can see the finished product.
Lee
I kept my eyes open in the classified ads for bowling alleys. People seem to sell this stuff around here about every six months or so. I went and purchased a 7' x 3'-6" x 2" thick section of solid hard maple. I purposely requested the front portion of the bowling alley because it has the alignment arrows in it, and they are inlaid walnut. I thought it looked cool. At any rate, the piece weighs hundreds of pounds, and makes a fantastic bench top. Be careful though, because only the first 25' of a bowling alley is maple (where the ball impacts). I got it for $15 per linear foot. I later bought some of the softwood portion of the lanes ($10/l.f.) to make assembly tables for my shop. Just don't ever relocate...too heavy!
For my top I contacted a door replacement store. I asked if I could look in their dumpster for a door that could serve as a workbench top. I found a very heavy steel, firerated door that used to be the entrance to a movie theatre. It was dead flat,thick,and long. I covered it with baltic birch. It's been in use for 35 years now.
I also saw, in the dumpster, several other particle board type doors that would have worked fine.
