I am currently building a workbench using the traditional bench plans from Lee Valley. The instructions call for tapering the wooden vise face by 1 degree so the face meets the bench at the top and shows a slight gap at the bottom. Does anyone know why?
I think it's to counter deflection.
Bill,
It's so when you clamp your stock in the vise the top of the vise contacts the wood first, and as you tighten it down the guides will move just a bit so the rest of the vise face will contact the stock. This ensures the work-piece will be held tightly with the entire vise face in contact with it. It's especially good to have a little more clamping force at the top of the vise than at the bottom; the stock is less likely to move as you do whatever operation to the bit above the vise.
Alan
Bill,
Other posts have explained why you taper so I won't go into that. However my experience is that 1 degree is not enough. I would go with at least 4 degrees.
Mark
