I just built a workshop and had the cathedral ceiling plastered (veneer plaster). Anyone have any thoughts about the color for the ceiling paint? I had thought I wanted it white to reflect the most light, but my wife suggested that pure white may be too harsh on the eyes. She suggested an off-white color such as “linen”. Any thoughts?
pure white
Greg
Exo 35:30-35
Dave,
I'd grab the decision "Linen" and run like hell...make sure you throw away the color charts as you leave. I've just spent two weeks determining an off-white with less yellow...whatever that is. However, I strongly suspect there is a reason why they call it "Ceiling White".
Dave,
I don't know how old you are but I find that I need more light than before to see well. So, I painted my shop ceiling "ceiling white".
If you do an actual lighting design there are factors to include for reflectivity of the ceiling/walls & floor. I didn't do the full calc, (too lazy, or not motivated enough, I guess.)
I'm going to paint the walls of my shop high white soon.
I'm more concerned with getting light on work surfaces as opposed to stopping glare. Also, remember, with a cathedral ceiling your sources, (light fixtures), will be further from your work surfaces, so the effective amount of light on the surfaces will be less.
This article is pretty technical: http://www.holophane.com/education/fundamentals.asp
Here's one that doesn't address wall/ceiling/floor color but has some good info on general lighting: http://www.taunton.com/finewoodworking/Workshop/WorkshopPDF.aspx?id=2771
Good luck.
Fred
Fred,Thanks very much for the information. I have also noticed the need for more light as I get older (just turned 55). I set up lights in my old basement shop based on the Jack Lindsey article, and really appreciated the light. I never would have used as many fixtures if it had not been for this article. My new shop has a cathedral ceiling in 2/3 of the space, so it is hard to exactly follow Jack's recommendations. My plan is to install fluorescent strips over 2/3 of the shop, and for the highest 1/3, put in 4 halogen spots pointing more or less onto my machines. This 1/3 of the shop ranges in height from 12 to 16 feet.As for the color, I think I will go with pure white, unless someone convinces me otherwise. I was in a Sherwin-Williams store over the weekend, and the sales guy told me they had some complaints about "ceiling white" as it sometimes ends up with a blueish tint.Dave
Dave,
You're wise to go with white. The actual tone of it doesn't matter much; the brighter the better.
Some people have mentioned "ceiling white" here a couple of times. Ceiling white paints are designed for use on ceilings in houses. They're very flat, non-durable paints; ceilings generally don't suffer much wear and tear. I'm not sure I'd use one in a wood shop though, as the flat surface would collect and hold dirt and dust, and cleaning it would result in smudging.
A better bet (and what I put in my shop years ago) is a semi-gloss paint. It is more reflective than a flat paint, and it is more durable when it comes to cleaning. So far, "cleaning" in my shop has consisted of either running a broom along the ceiling or blowing off the dust with my leaf blower. But still...
Zolton
If you see a possum running around in here, kill it. It's not a pet. - Jackie Moon
Zolton and Dave, I have found that a "super white" is made by most of the big box brands, I expect to reflect as much lumens as possible. I wonder if it comes in semi-gloss? Paddy
BTW. I never found the possum but I did find a groundhog in the cabbages last year with the help of Mr. Leoupold the 4th. My neighbor in TN was thrilled .
Paddy,
Ever hear that bluegrass song, "Groundhog?"
"Here comes Sal with a snigger and a grin,
groundhog grease all over her chin..."
ZoltonIf you see a possum running around in here, kill it. It's not a pet. - Jackie Moon
Z, not yet but I am sure my buddy has. He and his porch performers said that they would teach* me to play my 5 string. paddy
*I have to provide the beer, I already have a 53' porch.
I, too, like the idea of painting it "ceiling white", but then tossing the color chips and calling it "linen" to anyone who asks. Also, be sure to splotch a little paint on the can's label to cover your tracks while still at the task. ;-)
pure white
Ceiling white- forget the linen....after 6 months of good productive woodworking it will end up being Linen colored anyway.
I would go with the cheapest color I could fine that's close to white. Probably something pre-mixed. But that's just me.
Dave,
Each of the large paint mfg's. have a special "white" that's designed to reflect as much light as possible. It goes by many names. I would stick to a flat sheen.
Plastered ceiling in the shop---must be nice!!!
Mack
"Close enough for government work=measured with a micrometer, marked with chalk and cut with an axe"
