numpty error. Used wrong glue for exterior mail box project and didn’t realise until nearly finished. Used the right glue for brackets so at least it’ll hang there until it falls apart! :(.
Can I use a clear finish that will protect it from water ingress so preventing the joint failures ? Suggestions?
thanks.
I was a beekeeper for eight years. I bought kits out of Eastern White Pine for the hives. Each finger joint got yellow glue and one nail. The hives were painted with latex. They lasted fine in a hot, humid climate (central Arkansas). One hive that came with my first bee colony was painted with a clear varnish (probably a Marine type). It was old when I got it and still lasted. Of course bees put a resin called propolis in every crack and crevice on the inside of the hive to seal it against ants and for climate control. I sold all the hives with bees about six years ago for $300.00 a piece.
I’ve had bees and currently still have several hives but they are just nailed together, no glue needed.
I am in the uk an it’s wet a lot so the finish would need to seal it somehow.
I'd do just what you said and accept as many years as I got out of it. All outdoor project begin to self-destruct as soon as you place them outdoors.
I guess but frustrating
Paint it.
Paint will keep the moisture out as will most any exterior finish.
Made of oak and Wenge. Sacrelige to paint it! But thinking of applying copious layers of a outdoor clear finish. Maybe a boat vanish? Or silken?
