Y’know those things generally called reinforcing plates? They’re pieces of flat metal with holes through them for screws. I’ve seen them in the shape of an L, in the shape of an I, and in the shape of a T. However, I want some in the shape of a Y. That is, the angle between the arms would be 90 degrees, 135 degrees, and 135 degrees. Anybody know of a supplier?
You can contact a sheet metal manufacturer in your area and they can customize any size, shape, and gage to your specifications. If you are looking for an "of the shelf item", then maybe your local lumber yard can direct you to a supplier.
Have you looked on the Simpson Strong Tie Site
http://www.strongtie.com/
